Client Side Workspace Cache Encrypted?
  • August 27, 2012
  • 572 views
Cross-posted in the WCCI forum
With Pro/Engineer Wildfire 4 and PDMLink 10, are the contents of the client-side workspace cache encrypted?
In the middle of an internal discussion about whether the Pro/Engineerclient side cache should be located onthelocalhard driveor a network drive.
IT says moving the Pro/Engineer client side cache to a network drive mitigates the risk of a hard drive failure. I know that with Pro/Intralink 3.x, there were various ways for either another user to access someone's workspaces or to access a workspace from another computer.
I remember reading thatWindchill's Pro/Engineerclient side cache form the is encrypted and that the only way to access it is on the computer and user id that created it. I can't find a reference to it right now. Am I making this up?
TIA
--Andrew
You have essentially two questions, encryption of the local cache, and can the cache be remote.
Remote cache
The cache does not have to be local to the machine. We have a network with diskless workstations. I have a standard Dell t5400, but it has no hard drive. It boots off a drive image in the server room. On those machines I point the cache to the users working directory for ProE. You obviously want a fast network if you're going to put the cache remote from the computer. We have a gigabit network with optical cable. Still you're going to take a performance hit, and it's going to be significant.
Encryption of the local cache
