Column Rep Relations
- July 25, 2018
- 2 replies
- 1410 views
Relation Gurus...
In 4.0 is it possible to change items using relations when using column rep bom? I am pretty sure it was not possible in the past. I want to change a simple parameter in the repeat region that is cage_code. I am reusing someone else's model and I do not want to change their file. Their cage_code reads ---. I want to change mine to 96906. If it can be done, like I said, using multiple columns for assemblies, how do I write the relation? The bom column = as.mbr.cage_code. I can't seem to get it to work. I know I originally tried some time ago to change qty to AR...and that would not work. Was thinking maybe in 4?
Wayne
