Combining drawing files
  • September 2, 2014
  • 4 replies
  • 7461 views
Greetings all.
I have a situation where a series of parts and assemblies were designed and given individual part numbers and their own drawings. These subparts and subassemblies then go into a purchased part and are listed on a chart on the purchased part drawing. The issue is that we now want to combine all these parts and subassemblies drawings onto one purchase part drawing. Short of opening the purchase part drawing, adding the required sheets and redrawing every part and subassembly, does anyone know a way to combine these separate drawings into one large drawing?
I appreciate any assistance with this matter. Thank you all for your time and have a good day.
Best answer by StephenW
You can import a drawing in to another drawing. In Creo 2, in the drawing you want everything in, in the LAYOUT tab, go to INSERT drop down arrow, and select IMPORT DRAWING/DATA then select the drawing you want to add the current one.
If it is a multisheet drawing, it just adds it as the next sheet.
StephenW
StephenW23-Emerald IIIAnswer
That is worth deleting my reply Any limitations, Stephen?
SmartAssembly (3rd party product from Sigmaxim) also has a function to merge multiple drawings into one. It's probably just doing the same thing that Stephen mentioned, but it could be looped to merge all the drawings at once.
