Dale_Rosema
Component is family table driven and will use pre-Wildfire3 replace functionality
  • August 5, 2015
  • 4 replies
  • 2093 views
This shows up frequently in the comment section of the models.
Is it good / bad?
Is there a way to "fix" it if it is not good.
What causes it?
Thanks, Dale
Best answer by Mahesh_Sharma
Dale,
There is an article CS61196 about this message, possibly resolution in that correct it.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS61196
Mahesh_Sharma
22-Sapphire I
August 5, 2015
Dale,
Dale_Rosema
Mahesh Sharma
Is there a way to run that on individual files, or once I turn the config option, it will try to do that to everything?
Thanks, Dale
Mahesh_Sharma
22-Sapphire I
August 6, 2015
Dale,
This will be a manual process. Manually needs to update the files.
