Conductor Mass
  • March 20, 2015
  • 1077 views
Anyone understand how conductors are calculated for mass properties
reports?
Question I could not answer.
For example, where conductors may be routed prior to the connector entry.
In some cases they can be a significant amount of copper.
CREO sees these conductors as nonstd wire.
The standard spools are set-up with density at the twisted pair level. I
am assuming the density would have to be the same for the conductors.
Expanding the spool info, only Awg and color is entered. Should density be
added at the conductor level as well?
Douglas Bowles
Electro-Mechanical Design Eng.
520.794.7817
Cell 520.490.9395
PGR 520.281.6146
dbowles4-ParticipantAuthor
Jeff,
For example, If I route a conductor Only, from a spool set-up as shown
below 345 in long it will calculate as 0.00 Mass
When I route the cable (Twisted Shielded jacketed Pair) from the same
spool it calculates Mass
Cable has density
Conductor does not have density entered at conductor level
Douglas Bowles
520.794.7817
Cell 520.490.9395
PGR 520.281.6146
