configuration of Creo
Hi community,
I have a big question (actually many questions...)
How do you configure and set up Creo, I want to do the following:
I'm a PTC user since ProEngineer 2001 but have always been working on a configured version... (@ previous jobs)
As there was always an option to have your own mapkeys, config files.... I'm not totally unfamiliar.
And I also know to make symbols, setting up drawing templates and adding parameters to parts/assy...
Only, I started recently as Head Product Design Engineer (the whole team is only me atm, but others will join) in a new (blank sheet) R&D mechanical departement.
So, we just bought Creo 1.0 and I's up to me to configure all...!
This means:
- I want to be able to create MY standard parameters as you create a new part/assy/drawing...
- I want to create general config.win, tree.config,...
- Setting up tables, formats, units...
- Make a material database, symbol palette
- .... all you could imagine that needs to be done!
-> and all that should automatically load when Creo starts (that is also an issue)
And so on, all quite basic (it's not a huge company or departement), but more than PTC has foreseen as you do the installation.
Where could I find this kind of information?
Thanks in advance,
Didriek
