configurazione
  • October 16, 2017
  • 1531 views
Buongiorno,
quando esporto o importo disegni o file 3D ho dei problemi con la scala,
vengono importate in pollici e non in millimentri come vorrei,
ho provato a sistemare le impostazioni ma ho sempre il problema stesso,
anche le impostazioni disegno non riesco a salvarle come la proiezione in primo angolo mi va in automatico terzo angolo.
Grazie.
HamsterNL
18-Opal
October 16, 2017
Buongiorno to you too!
I have translated your message, English is the preferred langauge here 🙂
Good morning,
when I export or import 3D drawings or files I have problems with the scale,
are imported in inches and not in millimeters as I would like,
I tried to fix the settings but I always have the same problem,
even the drawing settings can not save them as the projection in the first corner goes to the third corner automatically.
Thank you.
