Contact interface connections
Hi All,
I am trying to run a simulation that has two steel tires running on four trunnions. I set up a contact interface connection between each trunnion and it's respective tire. Everything is fine until I try to run the analysis and I get insufficiently constrained elements in the shells between the tires. I did get it to run by suppressing the trunnions and creating a surface region on the tire that is constrained. This however, gives me higher stresses on the tire because it is a hard connection. Any thoughts on how to set up the constraints?
WF 4.0 M100
Jody
