controll of assembly components using relation
  • March 29, 2010
  • 3 replies
  • 1939 views
Hi All, I want to controll an assembly of 2 components using relations.Both are family instances; 15,20 etc. I mean,if i specify 15(defined parameter), both the components have to changed to same size ie. 15 NB. I may sound weired but is it possible and if yes please share your knowlodge. Regards Vishal
Thanks,but is it possible by using parameters???? regrads vishal
Vishal, It's relatively easy to do this with straight relations; your mixture of relations and family table calls is not readily doable. Using just Relations you can do a couple of things. For example, in the Assembly set up a Parameter called LENGTH. Now go to Relations, pick one of your parts to Edit and establish a relation by picking on the dimension and writing something like "d2:2=LENGTH". The ":2" is the key; it's an ID unique to a particular component in the assembly. Similarly, you could also set up a Parameter in the part called LENGTH, then in the assembly write "LENGTH:2=LENGTH". The 1st LENGTH is the one in the part; the 2nd is the one in the assembly. David
