Conversion of Assembly to VRML format
Hi!
I have been trying to convert an assembly to VRML format to 3D-print a model but when I do it in the most obvious way (save a copy-save as type-*.wrl), the assembly is broken in to several files relating to the assembly components and cannot be opened.
Similarly, when I do the same for single parts, the file does not open properly either.
I have also tried to convert it as an *.obj but this removes the colouration and reduces the polygon-count of the model when I open it in the printing programme.
Could anyone make a suggestion as to how to solve this?
Thak you 🙂
Ferdia
