Conversion of .prt to .stp from local
  • May 12, 2016
  • 4 replies
  • 4655 views
Hi All
I have few .prt file in a local ,how do i convert all the file to .stp with some script and without installing any 3rd part software ?
I am looking for mass conversion.
regards
Mahesh_Sharma
22-Sapphire I
May 12, 2016
Gagan,
You can use Distributed Pro/batch for mass conversion. BUT It needs to be installed with Creo (This is a part of Creo installation).
Check article https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS202462
it's the best way
You can create Map Key to convert all .prt file to step file.
Create may key starting from open-->pause map key to select part then resume it and give working directory at the time of creating map key. I think no need to install third party software. I have created 1000 part file to step file in one day by using two resources in single day.
I hope it might work for you.
Jitu Thakor
