convert real number into srting with decimals in relation
  • March 28, 2011
  • 18 replies
  • 14225 views
Hi all,
I am a pro-e user form a long. I have a problem with the concatenate function in relation.
I want to join a string & the dimension for the description of my model.
Ex. If the part name is Drain-line-01 & length of the part is 202.5mm.
Then the decription of the part is to be "Drain-line-01 202.5mm.
I created a parameter
Description "string"
L "real number" for the length of the part
I used a relation to achive it description = rel_model_name + " " + L + " " + "mm"
but i get an error.
error Invalid data type combination at right side of expression
I need this description with the decimals in the description
Please anybody help
Thanks in advance
Naresh,
try:
desc=rel_model_name+" "+extract(itos(L*10),1,string_length(itos(L*10))-1)+","+extract(itos(L*10),string_length(itos(L*10)),1)+" mm"
Martin
Nash1-VisitorAuthor
It worked great
Thanks Martin
Another thing I've done in the past is to create these types of descriptions as notes. You use the parameter names required and there is no need for a relation. In a repeat region it doesn't matter if the description is a different type from one model to another.
Nash1-VisitorAuthor
Hi Kevin,
I didnt get you, how can a notes be linked to a parameter can you please give an example
As example you could use a fastener description. It might have the thread type as well as the length of the fastener. Since you want to combine both text and real numbers you need to write a relation that converts the real numbers into a string. Another method is to create a model note. With a note you combine the part parameter names with the desired text. So you note might have the form: &d1-28 UNC X &d2 LONG. With this there's no need for a relation to convert the real numbers into text. For your parameter DESCRIPTION, if it's not already created you can change the type to Note when creating the parameter. If DESCRIPTION is already created as a String type you can change it by creating a temporary parameter of Note type and write a relation that sets DESCRIPTION equal to the temprory parameter and then delete the temporary parameter afterward. You won't see the note text when looking at the parameter list in part mode you specify the Note ID number which is found on the note properties dialog box. When you use DESCRIPTION in a note or repeat region it displays the text and will update with changes to the model. For your example the note might be: &model_name &d1 mm.
Kevin
I think that using note parameters instead of strings is a great idea to avoid having all the "real to string" conversions.
However, as far as i can see, you can not designate a note parameter if you want to capture the value in Windchill.
Do you have any idea if it is possible to convert the value of a note parameter back to a string using relations?
I think you're going to have to use Martin's method. You might be able to use a simpler format for the conversion of a real number to a string.
One other point of interest about using NOTE parameters to drive bill of material data. You can modify model dimensions directly from the note.
Let's say you had modeled an object from a piece of common stock (such as a structural angle) You might normally provide the height, width, and length information for such an object in your BOM description. For a simple piece of 2" angle, your DESCRIPTION might be similar to the following:
Angle, 2" x 2" x 1/4" x 25.00 Long
If you create this as a NOTE parameter instead of a string parameter (as Kevin suggested), you can have some of this data fill in automatically. Certainly when you modify model dimensions, the note will update... but if you double-click directly on the values in the note, you can modify the model dimensions, too.
In the example above, if you double-clicked on the "25.00", you'd be prompted to enter a new value. Upon regeneration, the model and note would both update to the new value.
