Copieing an flat state
Hy out there
I have the same problem over and over again.
When I copie an sheetmetalpart with flat state and drawing of the part and the flat state to another directory, I can't open the drawing because it misses the flat state. What can I do to avoid that problem.
While working on a project I sometimes make a part what is decided later that it can become a part to use in several projects. Those are in a different project called "standard parts".
Hope you understand I can't go one remaking the drawing and a new flat state each time I copie such a part too "standard parts".
Answers are wellcome.
Regards
Chris
