Copy of the model and associated drawings
  • December 3, 2014
  • 2216 views
Hi everyone!
I have one model and four drawings associated with him. There is a way to make a copy of this model and drawings using Creo Parametric?
Best answer by TomD.inPDX
There are several ways but the quick and painless way (painless=no data loss or corruption) is to back up the files to a new folder.
Open each drawing and use Save-As>Backup. This will force you to open a different folder for storing the files. Do this for each drawing and all the models loaded in memory for that drawing will be copied to the drive. You may end up with multiple copies but you can use "purge" in the command prompt to clean out the backup folder.
