Copying sheets in Pro Engineer
  • March 16, 2010
  • 5184 views
I have a drawing with and assembly on sheet one. I want to make a welding detail drawing on sheet 2 of the same drawing but don;t want to create all the views, centre lines again. is there a way that I can copy the stuff on sheet one onto sheet two so the two sheets look exactly the same??
3-Newcomer
March 17, 2010
U can try this: create a fresh drawing, go to edit> copy from other drawing.... copy the sheet that u want from the already created drawing. let me know if it works
It only copies the Baloons, Tables, notes and symbols on the drawing not the Geometry. Tried this right after I posted this. Thanks anyway for the input
Save a copy of the drawing (File>Save a copy) then insert the copied drawing to your current drawing (Insert>Shared Data>From File...). It will come in as the next sheet. This does not bring any shown dimensions in as they are already shown in the original drawing but it looks like it brings in everything else (views, formats, tables, ballons, notes etc). Hope that helps.
