Cosmetic thread printing
  • November 20, 2017
  • 3 replies
  • 3505 views
I am new to Creo Parametric 4.0, and I was wondering if 3D printers print cosmetic threads on parts, or if the threads have to be modeled manually to be printed? Thanks.
Best answer by StephenW
Cosmetic threads in the model are only a revolved surface.
For 3D printing, you'll need to model the threads...possibly a helical sweep, depending on your specific thread form.
StephenW
StephenW23-Emerald IIIAnswer
Wolfman1-VisitorAuthor
Do you also have to model the threads in a hole, or will it make them automatically if you choose a standard drilled hole size?
all threads created by Creo automatically are cosmetic features, only. They do not represent real solid geometry. If you need to 3D-print real thread you must create it in your model using solid features.
