Create a blend solid part wiht wariable section
I have a large quantity points coordinate for each section in excel file. These points divide between few plane. One case have a two plane. Another case I have a five planes.Therefore, a five different points data.The quantity of points for each plane a slightly different, all around 30 points for each plane. I need to create smooth solid blend extrusion. Part looks similar to wing or propeller. Problem: 1.After importing this point into offset point table, I can't make a curve, utilize exactly these points. 2. When I try to blend, I have always different number of verticals. Please, maybe somebody have a good reference material which provide step by step solution. Thanks everyone!
