Create a specific Law to motion in mechanism
  • December 20, 2018
  • 1432 views
In mechanism I'm trying to create a Motion of a specific component. I have the motion curve from supplier. This curve has its position along time. So how can I setup this motion? It's possible to draw this "law" on a sketch or graph, and link it to the motion?
In mechanisms, you have the server motor. There you can specify the type of motor that you need.
You can specify a motor with a function type by table, where you can define the position with time. You can define the position in an excel table, then export to .txt file.
