Create part name in a note
  • March 21, 2013
  • 15 replies
  • 8741 views
How can I get the part name in a note? I have tried &model_name, but then the name of the assembly is displayed.
Best answer by dgschaefer
Another way to do this is to find the part's session id.
Open the relations dialog (Tools tab > relations) and then pick Show > Session ID, pick Park in the pop up menu and then pick the part in question on screen. The session ID will be shown in the message area. Then create a note with this text '&model_name:ID where ID is the number you just found.
Another method would be to create a user parameter in your part tied to the file name. Enter the relation file_name = rel_model_name in the part's relation and then use &file_name:att in your note attached to the model.
If your note is attached to the edge of the model in question (and not an edge created by a section, for example), you shoudl be abel to use &model_name:att).
Dale_Rosema
Doug,
Is the ":att" the number of the model in the assembly? How do you find that number?
Thanks, Dale
sloman1-VisitorAuthor
Doug!
It works, thank you!
Dale_Rosema
What method did you use - the ID?
...if I need to check the corect information "att_mdl" for note in drawing - I create "fake relation" in assembly mode - system automatically create for me information (behind parameter in relation) and then I can use this number to my note in drawing
For example:
Now I have made a "mapkey" to search for the session ID. In the mapkey is also the command for making the note. It takes seconds to place the part numbers in a assembly.
I like mapkeys too -
Here is some Trisks with Mapkeys and video Hide custom Layers with Mapkeys
I have created idea for new release
What do you think? Vote here: Enable Show/Hide Session ID in Model Tree
For some reason I have found that I have to enter the parameter in lowercase &model_name and uppercase &MODEL_NAME does not work. For multi-part drawings, whatever model I have active, ProE / Creo will append the correct number at the end e.g. &model_name:12
