Creating a knurled surface in WF 4.0
  • April 28, 2011
  • 16 replies
  • 18318 views
Is there an easy way to create a knurled surface in WF 4.0? Here is a jpg of what I'm trying to knurl.
Hello Christian
If you need to create knurl, use standard features: Sweep cut (1. Crate Curve >>> 2. Insert>Sweep>Cut and than you can Pattern created features).
Second option: Create Helical Sweep feature.
Vladimir.
... maybe easy way is create custom color defined with knurl texture (download here or here)
Vladimir,
Your texture suggestion is a clever idea; I've done something similar in the past by just patterning crossed helical datum curves on the surface, but the texture is even better.
David
Christian,
Check this out for details:
http://www.ptc.com/cs/cs_25/howto/agf362/agf362.htm
Just be aware that including a lot of knurls, like including a lot of threads, in a model can impact regeneration time.
If a cosmetic approach such as the one Vladimir suggested works for you, you are probably better off.
David
Hello Christian
I am inclined to believe that it is better to have cosmetic features as the full geometry (in this case)
Vladimir
I'm trying to create a custom color using the JPG I downloaded but can't seem to figure it out. Is it possible to do this in WF 4.0?
