Creating Artifacts in Creo Schematics
- November 17, 2011
- 2 replies
- 3744 views
Hi All,
I want to layout a wiring diagram of my starter and charging circuit for my 83 Honda Magna. The components are as follows:
Alternator > ??? (3) ports
Rectifier / Regulator > Control Module (8) ports
Solenoid > Relay (5) ports
Starter Motor > ??? (1) port
Ignition Switch > ??? (5) ports
Starter Switch > Push Button Switch (4)
My question is do I have to design new artifacts that have the physical charactics of the above components that I placed the ??? beside or can I use an existing artifact. I am modeling the frame and placing the modeled components in their correct locations. I want to bring in the XML file into my frame assembly and auto-route the wires.
TIA
