Creating hole in ellipse shape..
  • January 27, 2010
  • 11 replies
  • 3983 views
Hello Buddies
Kindly tell me how to creat holes in ellipse shape. I need to pattern the hole in ellipse shape. Please find the image file. Kindly reply its very urgent..
Suganthan Rajamanickam
Pro-e System Analyst
Trane Design Centre, India
Ingersoll Rand
Could you create a ellipse-shaped extrusion and simply select *remove
material* away the shape?
On Wed, Jan 27, 2010 at 9:01 AM, Suganthan Rajamanickam <
-> wrote:
> Hello Buddies
> urgent..
> *Suganthan Rajamanickam *
> *Pro-e System Analyst
> Ingersoll Rand
Firstly, I believe that's an oval, not an ellipse (an ellipse is a
circle stretched in one axis). If you had wanted an ellipse, it might
have made sense to use some equations somehow...
There are several solutions.
The easiest, assuming that the points you show are patterned, would be
to create an axis through the pattern leader of the points, then create
a hole on the axis, then reference pattern the axis and then the hole.
Reference patterns are extremely powerful and very useful.
If the points aren't patterned, you could create the first hole and then
copy and paste it onto each point (again, you may need to create an axis
first).
Or you could ignore the points completely, create a semicircle pattern
of holes and a line pattern of holes, and mirror each of these.
HTH,
Jonathan
Ingersoll,
1- Sketch the curve
2- Create the hole on an endpoint (See yellow arrow for start point)
3- PATTERN -> CURVE (specify the spacing)
[cid:image001.gif@01CA9F3F.2B653710]
[cid:image002.gif@01CA9F3F.2B653710]
You can create a sketched curve and do a fill pattern on it. I've done it
once, but don't remember the details of the steps involved. I'm sure someone
here can elaborate...
One other possibility would be to calculate the x,y locations of the
holes and use a pattern table to fix the locations.
I thought Pro/E could pattern along a curve now, as well. Can't say
I've done it, but theoretically you could make a curve in the shape of
the ellipse and then pattern the holes along it.
T
It can, as of WF3. It's very useful - suppose you want 8 equidistant holes,
centered on a part, but want to be able to have the distance change as the
part length changes, since you're still iterating your design. Sketch a
straight curve, centered on the centerline, create your hole on one end of
the curve, select pattern > curve > select the curve, change the criteria
from distance to number of holes, set the #, voila!
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
Hole tables are just a tidy way to produce several identical holes at a
range of different positions - you can type in all the coordinates (x
and y, or radius and angle) in one place rather than creating lots of
independent features.
I don't have a lot of experience using top-down design, but when I've
tried to use reference patterns with inherited or published geometry it
seems more difficult. I'm copying back to the list to see if other
people can help.
If whichever method you choose needs you to input an extra dimension,
then it won't update with the parent unless you create some sort of
external relation.
Jonathan
Translating patterns through copy and publish geometries is possible,
just cumbersome.
* First, create the pattern.
* Now add the leader only to a publish geom feature
* Now pattern the publish geom by reference.
* In the target model, create a copy geom and select the leader of
the publish geom pattern
* Now you can reference pattern the copy geom
Now that I think of it, the publish geom may be unnecessary in this
instance. In that case, simply select the pattern leader for your copy
geom. The publish does give you extra flexibility if you decide later
to remove the pattern, I guess.
Anything else you want to copy into this model will have to go through
another copy / publish geom pair.
Doug Schaefer
Doug,
Sometimes I miss CADDS... where all you had to do is specify and orient a
hole with a major width and minor width... once it WAS so simple.
Glen R Wisham
Sr Technical Support Engineer
SAS Electronic Warfare Systems
Raytheon Company
(business) 805.879.3359
(fax)         805.879.3017
6380 Hollister Ave
Goleta, CA 93117-3114 USA
www.raytheon.com
This message contains information that may be confidential and privileged.
Unless you are the addressee (or are authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
Doug Schaefer <>
01/27/2010 09:15 AM
Please respond to
Doug Schaefer <>
To
cc
Subject
[proecad] - RE: Creating hole in ellipse shape..
Translating patterns through copy and publish geometries is possible, just
cumbersome.
In the target model, create a copy geom and select the leader of the
geom.  The publish does give you extra flexibility if you decide later to
Doug Schaefer
                                                 designet
6464 Presidential Gateway
Columbus, Ohio 43231
USA
Try pattern on curve. I just tried it using your shape for the curve and
it is very easy!
Dave Martin
Sr. Industrial Designer
The Toro Company
