Sep 5, 2026 12:48 PM UTC
Creo 11.0.2: &PRO_MP_MASS[.2] Sometimes Fails to Format the Decimal Places
Hello everyone,
I have encountered an issue in Creo Parametric 11.0.2 that has been bothering me for many years. I hope someone can explain the reason or provide a reliable solution.
I want to display the model mass in a drawing title block or a regular note, rounded to two decimal places:
&PRO_MP_MASS[.2]
For example, if the actual mass is:
0.058
it should normally display:
0.06
However, sometimes it displays:
0.058[.2]
In other words, the value of PRO_MP_MASS is correctly retrieved, but [.2] is treated as plain text instead of being interpreted as a decimal formatting modifier.
What is even stranger is that if I edit the same note and temporarily change it to:
&PRO_MP_MASS
After confirming, I edit it again and change it back to exactly:
&PRO_MP_MASS[.2]
it may immediately display correctly as:
0.06
During this process, I do not modify the model, material, or mass properties. I only re-edit the note.
This issue can occur both in the title block and in regular drawing notes, so I suspect it may be related to parameter note parsing or refresh behavior.
Has anyone encountered a similar issue? Is this a known Creo problem? Is there a reliable automatic solution suitable for company drawing templates, without requiring users to manually re-edit the notes?
Emeritus
Sep 16, 2026 4:24 AM UTC
Hi ​@WP_14104464,
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Vivek N
Community Moderation Team
Sep 16, 2026 10:27 AM UTC
I see a space between [ and the decimal point .2]
it should be [.2] instead of [ .2]
Also, for a value of 50.056 to be rounded to 50.06, the syntax should be 50.056[.2] and not 50.056 [.2]
Knowing, what we know is just a fistful of Earth, brings in humility.
Sep 19, 2026 1:11 AM UTC
I'm certain that there is no space between [ and .2].
What's more frustrating is that placing &PRO_MP_MASS[.2] into a table cell in the title block is very hard to keep updated — sometimes it refreshes, sometimes it doesn't, and most of the time it simply doesn't update at all, even after I run Analysis > Mass Properties in the model file, or press Ctrl+G to regenerate the model.
However, when I place it as an annotation (note) directly on the drawing, or add a mass column to the BOM table (parts list), updating works much more reliably.
My config option setting is: mass_property_calculate = by_request.
Sep 29, 2026 5:30 AM UTC
Try mass_property_calculate = Automatic
Many a times mass property values change after at least 2 Ctrl+G depending on how the geometry is constructed.
Also Refresh the screen.
3-Newcomer
Nov 12, 2026 12:27 AM UTC
In older versions of Creo I found that this works. I hope this helps.
&PRO_MP_MASS:mdl[.2]
