Creo 2 Admin .ui/ribbon questions
Hello All,
I'm setting up a base (admin) ui file for our team that will contain some company mapkey icons, shortcuts, etc. This admin ui will be read only and each member will have their own to customize on top of it per this outline (thanks to Vladimir Palffy). I have a few questions:
1. First off, does it work as advertised? Can I keep the admin ui locked down and controlled while the users apply there own changes over the top of it? Or is there wacky side affects?
2. So far i've found there are 6 ribbon/quick access toolbar environments that need to be set up separately; prt, sheetmetal prt, asm, drw, sketcher, and startup. And each has its own quick access toolbar. Am I missing any?
3. Should the admin UI be named creo_parametric_admin_customization.ui or admin_creo_parametric_customization.ui? I've found it listed each of these ways on the internet.
Also, load_ui_customization_run_dir is set to NO as I don't want 50,000 .ui files floating around.
thanks for any info!
Jared
