Creo 2 & Intralink 3.4
  • June 3, 2013
  • 3 replies
  • 2476 views
Has anyone tried Creo 2.0 with Ilink 3.4?
Does it work at all?
Cheers,
John
Best answer by BrentDrysdale
Hi John,
I guess people assumed you had found out about it in some other way
The answer (as I understand it) is that you can only use Intralink 3.4 for up to and including WF4. The last conference I went to in 2010 had many very angry questions about ongoing Intralink 3.4 (and beyond) support for WF5 with many companies staying on WF4 until they could get a resolution. There never was a resolution as Intralink stops at 3.4 and PTC want you to use Windchill in some flavour to do your CAD and other file managent. PTC have put a massive push on Windchill and it can do a lot however for many users this was way over the top and they liked the simpler (and very robust) Intralink 3.4
So to Recap WF5, Creo 1+2 cannot use Intralink 3.4 and you need instead to use Windchill as Pro/Intralink (not the same thing as 3.4) or the Windchill PDM Link. Windchill is massively powerful but it takes more to set up and administer.
PTC did introduce a simpler product Productpoint based on MS Sharepoint about three yeas ago but dropped it after release 1.0
PTC do now have a pared back version of Windchill that is supposed to be simpler to install and run for just PDM. Have a look at
http://www.ptc.com/product/windchill/pdm-essentials/
and see if this has any relevance for you.
Hope this helps.
Regards, Brent Drysdale
JWayman1-VisitorAuthor
I'm astonished that no-one even has an opinion on this.
Not even to advise me not to be so stupid as to think about it!
Dale_Rosema
Sorry - No Intralink here.
Hi John,
Hope this helps.
