CREO 3.0 Axis not shown when view select
  • November 6, 2017
  • 4 replies
  • 2646 views
Hi all users
Why, whith the new version of CREO3.0, when you select a view (in a drwaing), it's not possible to show all the axis of this view ?
The only possibility we have found it's to select each component (part only, not assy).
Best answer by Mahesh_Sharma
Set config option show_axes_by_view_scope to all_sub_models, it will help you.
StephenW
PTC changed the show functionality when selecting by view of asemblies. There are times if you show dimensions or axis by view it would take a long time (large assembly).
If i'm not mistaken, it now only shows the top level axis when selecting by view (of an assembly).
Mahesh_Sharma
22-Sapphire I
November 6, 2017
ldrutel1-VisitorAuthor
Amazing !!
Thank you KSM
Mahesh_Sharma
22-Sapphire I
November 6, 2017
If this solved your issue, mark the port as resolved.
