Creo 3.0 Creating Multiple Notes
  • January 12, 2018
  • 1841 views
In all previous iterations of Pro-E / Creo, you could create multiple notes without being kicked out of the action.  How do we accomplish this in Creo 3.0?  We cannot see a way to complete a note without being kicked out of the process and thus having to go up to the ribbon and re-select the action.  Between this and the new dimension selection process, they have significantly affected the amount of time required to complete a drawing.  I feel like my racecar has the parking brake stuck.  It is starting to feel slow and tedious like Inventor.
I don't think that's possible directly.
But Mr. @VladimirPalffy from PTCCommunity has developed Repeat Last Command utility for Creo 4.0 to do the same.
https://community.ptc.com/t5/Creo-Blog/New-utility-for-Creo-Repeat-Last-Command-in-Creo-Parametric/bc-p/495547#M2092
http://4kside.com/en/download.html
One user has commented that it works with Creo 2, So I'm guessing it will work with Creo 3.0 as-well.
Just give a try.
