Creo 3.0 Memory Leak
  • May 17, 2017
  • 2 replies
  • 2343 views
Has anyone else noticed Creo 3.0 having more issues with memory leaks than previous versions? We have been on M090, M120, and currently on M130.
I have the Visual Worker for Windchill running on its own machine with 16GB of RAM and every single day it gets up to 10-14GB of ram being used by xtop.exe alone... I've also had a couple engineers report this issue too and they just have to Save everything and close out of Creo.
Figure this is just a bug, but didn't know if there were any workarounds or advice from anyone?
Thanks!
I too am experiencing this with my visualization worker.  All of a sudden it will start leaking memory and if not caught in time freezes the server.  Strange thing is I can start the object over again that caused the memory leak and it will run fine after either a shutdown of the processes if caught in time or a reboot of the server.
Has anyone figured this out or have a solution for it?
Similar behavior here ( 3.0 M150 )
Open a large assembly, do nothing and wait 30 minutes, creo ram usage increase.
