Creo 3 Right Click Option
  • February 3, 2017
  • 10 replies
  • 7737 views
Hello All,
We have just upgraded to Creo 3.  I was wondering if anyone has experienced the same issue as I am having.
When I modify section views, after some time the right click mouse button stops working.
The menu appears quickly and the disappears and I am unable to click any of the options.
The only way around it is to shut down Creo and open again.
Has anyone else experienced this?
You are not alone, this issue has been mentioned in other threads/forums. Do you have any 3D mouse in use? I use 3Dconnection Space Mouse Pro and I suspect that is causing the problem like some other users have reported.
Make sure your graphics card is supported by 3.0. Then make sure you are using a supported/certified graphics driver (not necessarily the latest) . Then make sure your mouse drivers are up to date.
aedward1-VisitorAuthor
Thanks for the replies.
Timo Nurmi - I use a 3d Connexion mouse.
Dan Harlan - I will try to look into the graphics card.
Found a solution on the following thread:
Re: Context (RMB) menus disappear in WF5
If the menu disappears, closing other open windows solves the problem.
I have to try this next time the problem occurs. However, I wouldn't call this a solution but a workaround.
Thanks for sharing!
We have multiple customers experiencing this in all versions of Creo 3 and also in Creo 4. Most have it in drawing environment, some in part or assembly mode. RMB on model tree never seems to give problems.
There seems to be a relation with 3Dx mouses and indeed repaint helps sometimes but closing all other windows except the one you're working on works for almost everyone.
PTC has not been able to reproduce this problem in 1.5 years. If anyone has more specifics on what is causing this or knows a way to reproduce it please come forward so PTC can finally solve it.
I can reproduce the problem. If i light up the feature i want to change the feature the menu flips away.
If i light up the feature i want tot change and i go to the drawing field area and than use the right button it works well. It is a problem in Creo with the drawing window and not with the mouse or 3D mouse. I cant understand why PTC can't sollve such a simpel problem.
I mean drawing tree area.
