Creo 4.0 modeling - view re-orients whenever saved
  • June 18, 2018
  • 929 views
Just last week my company upgraded to Creo 4.0 from 2.0.  In 4.0 whenever the save button is clicked, the model/assembly on screen will re-orient to the default ISO orientation and switch from shaded with edges to shaded.  I suspect this is a setting within the config file, but a thorough search of the config file did not reveal anything.  I also consulted Google to see if an answer to this question was out there already, but could not find an answer.
What I want: the view of the model/assembly on the screen to not change when I click save.  This is an annoyance that my coworkers and I are seeking a solution for.
Thank you for any assistance that can be provided!
1.] save model using File > Save command ... how does it work ?
2.] check whether save button does not run mapkey
