bbrejcha
Creo 5.0 user interface docking issue
  • July 13, 2018
  • 2 replies
  • 1685 views
You may not know this but in Creo 4 and Creo 5 users can slide a pull down out of the UI.  I call this un docking a dialogue box.   While  an External Copy Geometry Tab I un-docked the 'References' Tab and the un-docked dialogue went just out of reach above my screen resolution above the 1950 on my Dell Windows 10 UI  and  I can not select it to get it back down.
I tried:
1 Re-staring Creo 5.0
2 rebooting Dell Precision machine
3 re configuring the install
4 setting dual displayed & extended displays & rotating the display
I would like to set another display that would reach above 1950
SUGGESTIONS?
Bart Brejcha
Design-engine.com
Mahesh_Sharma
22-Sapphire I
July 13, 2018
You can use:
1. File > options > Windows Settings > Click on "Rest Panel's Position". OR
2. Clear .ui file in cache
https://community.ptc.com/t5/Part-Modeling/Placement-disapperaed/m-p/288457/highlight/true#M25239
bbrejcha
bbrejcha15-MoonstoneAuthor
I was hovering around that option setting but did not click on it 😉  Thanks for pointing me in the right direction!
Bart Brejcha
Design-engine.com
Bart Brejecha designengine.com
