creo config option "hidden lines" viewstyle for drawings
  • December 15, 2011
  • 5 replies
  • 5367 views
Does anybody know a option to configure creo to use always the style "hidden lines" for views in drawings?
Best answer by MichaelHacker
ok, solved by myself... fyi it has to be defined in the dtl with model_display_for_new_views
MichaelHacker12-AmethystAuthorAnswer
How do I edit the dtl?
In Creo: File/Prepare/Drawing Properties/Detail Options - change and you can Save a Copy with the little Dual-Disk icon. Then you can load a configuration with the little Folder icon (<= seems a wierd icon for this!)
