Creo Elements/Pro Dimension Text Style
In previous release we were able to change the Letter of a dimension to bold (filled) that had a tolerance without changing the tolerance also.
{0:@O}{1:L}{2: # .02}
Selecting the "L" to change the style to filled results in the entire line changing to "filled".
Has anyone come across this and do you know what syntax it should be to work?
