Creo integration in MathCAD
Have a good day,
This is Hari, Amhaving doubt on integration of Mathcad In creo.
For example:
The output result from Mathcad is my input to model. How can i integrate..
Awaiting your repliess...
Regards
Hari Krishnan
Please check this video:
Hari,
You write Relations in your Creo model to make a part or assembly dimension a function of, or equal to, one of the Mathcad outputs.
Are you using an embedded worksheet or a Prime Analysis feature?
Hi Dave,
I'm using an embedded worksheet with my creo model. Is there a way for the values to update automatically when performing and Regen?
Bryan
With embedded worksheets, I believe the answer is no. You have to use a Prime Analysis feature (part of BMX) for that.
