Creo mirror part
  • September 17, 2015
  • 2 replies
  • 1990 views
When I use mirror in part mode I usually prefer to mirror the complete part.
Is there any way to exclude planes from being mirrored.
I usually have no use of the mirrored planes and I prefer to add mates in assembly to original planes like side or top plane.
Wrong planes can easily be selected by mistake.
Best answer by KenFarley
No. Mirror the complete part and you mirror everything in it, including planes. You can "hide" the mirror feature afterwards, which makes a lot of the stuff invisible.
KenFarley
KenFarley21-Topaz IIAnswer
You can mirror the geometry in a couple steps. Once you have one side designed select a surface and then right click to select all solid surfaces. Then Copy and paste. Then mirror this new copied surface to the other side. Then solidify the new mirrored surface quilt.
