Creo Options modeler Question .
  • August 12, 2015
  • 2 replies
  • 1146 views
Hi i am using creo options modeler to build a configuration assembly , the assembly has multiple modules and each modules has  a few small subassemblies,
But the subassmblies repeat in multiple modules at different locations in the assembly and these  are assembled in various angle.
But i am not able to bulild the configuration assemble, when the parts  or subassemblies are repeating, i have tried replacing with copies, but then the end Bill of material gets affected, any help will be appreciated.
Thanks in advance.
Naren
Narendarv1-VisitorAuthor
I was able to solve this.....
18-Opal
August 21, 2015
Hey Narendar,
That's great that you were able to find the solution.  Would you mind sharing it here and also marking the thread as answered.
Amit
