Creo Parametric 3.0: Swept blend fails to regenerate
- 1 reply
- 2610 views
- Translate All
Hello
I am trying to construct geometries for different wing configurations using swept blend on a defined trajectory. While this method works for some of the wing configurations I have, for some of the designs ( file attached herewith ), after 24 odd sections, the adding 25th section along the span causes a failed regenration. All the wing sections exactly the same ( rectangular wing ).
My steps are as follows : select slpine > add points ( 42 points in total ) > select spline > swept blend > sections > insert > select point > sketch > File > wing_section.sec > rotate > scale > parallel & perpendicular corrections > ok.
These steps seem to work for all the sections but sections 25 and above.
The parallel and perpendicular factors are : 0.001408 and 0.15378. The local incidence for the wing sectio is -3.02 degrees.
I am not sure what is going on here.
The CAD files are attached herewith.
Thank you in advance
