Creo Simulate moving reference frame
  • August 8, 2017
  • 1601 views
Good morning,
I have a question about moving reference frame.
I have created a coordinate system on a face of the component that I am simulating - static simulation - with z axis normal to the surface and all the references selected with respect to the face geometrical features.
Then I have imposed a displacement along the z direction of this coordinate system, because I want it to be normal to the surface. The question is: if the face face moves (suppose for example that it will rotate), will this reference frame always move with it (such that the z direction will always remain normal to the face) or will it remain fixed as I had defined it during the set up of the simulation?
No large displacement option has been selected.
Thank you very much for the support.
Bets regards
2-Explorer
November 28, 2017
No; a moving reference frame is nonlinear. I don't think Creo has the capability to do followers expect for pressure loads.
