Creo Slow while navigating sheets
  • October 16, 2013
  • 11 replies
  • 7117 views
Hi Guys,
I am using Creo 5. We are using large assemblies in my drawing.
The problem is while navigating the drawing sheets it takes about 5 - 10 minutes from one sheet to another sheet.
The graphics card is high specification
If there are any tips that could be followed to make it fast please provide here.
Best answer by HugoBarosa
Hi
Your problem is all about smart filter in bottom right corner. Try to choose another filter such as Anotation or symbol and you will get really faster.
Drawing Representations could be the way to go, depending on what you are doing in your drawing.
To open the drawing quickly select the drawing and Open Rep - go for No Views and it will open without the models and without views.
You can then use Tools > Drawing Representation > Create (if you do not have this option then your licence cannot create drawing representations so stop reading now!)
Drawing reps carry out a number of commands in the order in which you put them into the Drawing Rep Tool dialogue box.
Make a tick next to 'Delay View Command(s) Until Execute and then for example start with Erase all views (the default if you open No Views), then you can say Display Individual views, all views on sheet x etc. remember to use the Add button and when you select Execute it will carry out your commands. The Drawing Display tab allows you to automatically go to a selected page/view and things like that so you can really streamline your drawing activity.
Hi
Go to tools / options Find force_wireframe_in_wireframe and set to yes by default. You can change in config.pro directly
Close Proe and start again, hen you open the drawing you will see the diference in navigation in drawing sheet.
You can create 1 macro that is force_wireframe_in_wireframe no and only when you need to export/print you apply the macro that you have created.
Best regards
Magno Bastos
Hi
Hi
Hugo, read carefully what Vivek Rajan wrote, the problem while navigating the drawing sheets it takes about 5 - 10 minutes from one sheet to another sheet ie becouse every time we change from sheet, before the next sheet to be displayed must be update, has nothing to do with the smart filter!
The quickest way to open the next sheet without wasting much time is disable the force_wireframe_in_wireframe and set to yes by default
Vivek, try and give us feedback
Magno Bastos
Hi, already did. But i manage to reduze lots of time between sheets with the smart filter.
It takes only 5 seconds to try so no big deal.
Hi Vivek Rajan, I switched the option is:
force_wireframe_in_drawings yes
Sorry
Magno Bastos
