3-Newcomer
January 30, 2026
Creo tf_a4.frm 模板工程图 start 定位注释消失致 SVG 导出 BOM 偏移
  • January 30, 2026
  • 180 views
问题反馈:Creo tf_a4.frm 模板工程图 start 定位注释消失致 SVG 导出 BOM 偏移
问题现象:使用 tf_a4.frm 最新模板制作带爆炸视图的工程图,为满足 SVG 导出需求添加「start」定位注释符号;执行【工程图保存 + 关闭 + 拭除未显示】操作后重新打开图纸,会触发系统弹窗警告,无论选择「继续」或「审阅」,添加的「start」定位注释均直接消失;最终导致该工程图导出的 SVG 文件中,右侧 BOM 清单位置出现偏移,无法正常对齐
Community Moderator
February 6, 2026
Hi @GD_14314423
Thank you for your question.
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Best Regards,
Vivek N
Community Moderation Team
