Creo "thinks"/locks up, have to exit
  • August 30, 2017
  • 1457 views
I'm experiencing an issue with Creo "thinking"/locking up simultaneously.  Once this happens, I cannot choose any other option in the software and I'm forced to manually end the task.
We do not have PDM.  I am working from a shared server.  I backed up one of the drawings/models to my desktop to see if it was an issue with the company servers and it did the same thing (thinks/locks up, have to exit).  There is a common denominator with this:  Inserting a row to a table (no parameters/relations in tables i am adding rows to) causes the crash and it happens every other drawing i revise.
I'll change one drawing, save changes, export print, exit drawing, erase not displayed.  Open a new drawing, do the same changes and once i click to insert that new row, it locks up and thinks forever.
Here is the trail file info:
~ Command `ProCmdModelOpen`
< REMOVED
~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` \
`file_open`
~ Activate `file_open` `pb_favorites__FAV_9_`
~ FocusIn `file_open` `EMBED_BROWSER_SEARCH_IP`
~ Input `file_open` `EMBED_BROWSER_SEARCH_IP` `X`
~ Input `file_open` `EMBED_BROWSER_SEARCH_IP` `XX`
~ Input `file_open` `EMBED_BROWSER_SEARCH_IP` `XXX`
~ Input `file_open` `EMBED_BROWSER_SEARCH_IP` `XXXX`
~ Input `file_open` `EMBED_BROWSER_SEARCH_IP` `XXXXX`
~ Input `file_open` `EMBED_BROWSER_SEARCH_IP` `XXXXXX`
~ Input `file_open` `EMBED_BROWSER_SEARCH_IP` `XXXXXXX`
~ Update `file_open` `EMBED_BROWSER_SEARCH_IP` `XXXXXXX`
~ FocusOut `file_open` `EMBED_BROWSER_SEARCH_IP`
~ Select `file_open` `Ph_list.Filelist` 1 `XXXXXXX.drw`
~ Activate `file_open` `Ph_list.Filelist` 1 `XXXXXXX.drw`
!Command ProCmdModelOpenExe was pushed from the software.
!30-Aug-17 09:15:43 Start G:\Cad\Released\XXXXXXX.drw.2
!30-Aug-17 09:15:43 Start G:\Cad\Released\XXXXXXX<XXXX_XXXXXX>.prt.36
!30-Aug-17 09:15:43 Start G:\Cad\Released\XXXX_XXXXXX.prt.36
!30-Aug-17 09:15:44 End G:\Cad\Released\XXXX_XXXXXX.prt.36
!ProgressBarDlg: Regen Started
!%CIRegenerating XXXXXXX feature 5 out of 138 ...
!sket_eps REMOVED
!mem_use INCREASE Blocks REMOVED, AppSize REMOVED, SysSize REMOVED
!%CIRegenerating XXXXXXX feature 6 out of 138 ...
!%CIRegenerating XXXXXXX feature 7 out of 138 ...
!%CIRegenerating XXXXXXX feature 8 out of 138 ...
!%CIRegenerating XXXXXXX feature 9 out of 138 ...
!%CIRegenerating XXXXXXX feature 10 out of 138 ...
!%CIRegenerating XXXXXXX feature 11 out of 138 ...
!%CIRegenerating XXXXXXX feature 12 out of 138 ...
!%CIRegenerating XXXXXXX feature 13 out of 138 ...
!%CIRegenerating XXXXXXX feature 14 out of 138 ...
!%CIRegenerating XXXXXXX feature 15 out of 138 ...
!%CIRegenerating XXXXXXX feature 16 out of 138 ...
!%CIRegenerating XXXXXXX feature 17 out of 138 ...
!%CIRegenerating XXXXXXX feature 18 out of 138 ...
!%CIRegenerating XXXXXXX feature 18 out of 45 ...
!%CIRegenerating XXXXXXX feature 19 out of 45 ...
!%CIRegenerating XXXXXXX feature 20 out of 45 ...
!%CIRegenerating XXXXXXX feature 21 out of 45 ...
!%CIRegenerating XXXXXXX feature 22 out of 45 ...
!%CIRegenerating XXXXXXX feature 23 out of 45 ...
!%CIRegenerating XXXXXXX feature 24 out of 45 ...
!%CIRegenerating XXXXXXX feature 25 out of 45 ...
!%CIRegenerating XXXXXXX feature 26 out of 45 ...
!%CIRegenerating XXXXXXX feature 27 out of 45 ...
!%CIRegenerating XXXXXXX feature 28 out of 45 ...
!%CIRegenerating XXXXXXX feature 29 out of 45 ...
!%CIRegenerating XXXXXXX feature 30 out of 45 ...
!%CIRegenerating XXXXXXX feature 31 out of 45 ...
!%CIRegenerating XXXXXXX feature 32 out of 45 ...
!%CIRegenerating XXXXXXX feature 33 out of 45 ...
!%CIRegenerating XXXXXXX feature 34 out of 45 ...
!%CIRegenerating XXXXXXX feature 35 out of 45 ...
!%CIRegenerating XXXXXXX feature 36 out of 45 ...
!%CIRegenerating XXXXXXX feature 37 out of 45 ...
!%CIRegenerating XXXXXXX feature 38 out of 45 ...
!%CIRegenerating XXXXXXX feature 39 out of 45 ...
!%CIRegenerating XXXXXXX feature 40 out of 45 ...
!%CIRegenerating XXXXXXX feature 41 out of 45 ...
!%CIRegenerating XXXXXXX feature 42 out of 45 ...
!%CIRegenerating XXXXXXX feature 43 out of 45 ...
!%CIRegenerating XXXXXXX feature 44 out of 45 ...
!%CIRegenerating XXXXXXX feature 45 out of 45 ...
!%CIW031610 regeneration completed with 20 suppressed feature(s) or component(s).
!ProgressBarDlg: Regen Completed
!30-Aug-17 09:15:44 End G:\Cad\Released\XXXXXXX<XXXXX_XXXXXXXX>.prt.36
!30-Aug-17 09:15:44 Start G:\Cad\Released\01_b_eng.frm.1
!30-Aug-17 09:15:44 End G:\Cad\Released\01_b_eng.frm.1
!30-Aug-17 09:15:44 Start G:\Cad\Released\page2.frm.1
!30-Aug-17 09:15:44 End G:\Cad\Released\page2.frm.1
!30-Aug-17 09:15:44 Start G:\Cad\Released\inspect5.frm.1
!30-Aug-17 09:15:44 End G:\Cad\Released\inspect5.frm.1
!30-Aug-17 09:15:44 End G:\Cad\Released\XXXXXXX.drw.2
!sket_eps 1.515389258
!sket_eps 7.576946288
!sket_eps 62.775
< REMOVED
~ Activate `main_dlg_cur` `page_Table_control_btn` 1
!Drawing context was changed by user from page_Layout to page_Table
~ Wheel `main_dlg_cur` `proe_win`
~ Command `ProCmdDwgTblInsertRow`
!%CPPick location in table to insert row.
~ LButtonArm `main_dlg_cur` `proe_win`
~ LButtonDisarm `main_dlg_cur` `proe_win`
~ Close `rmb_popup` `PopupMenu`
Mahesh_Sharma
22-Sapphire I
August 30, 2017
If this is reproducible, Submit a ticket to PTC support.
Try recreating the same scenario using default settings (without config/mapkeys and all).
Is it generating any traceback?
