Creo Tool Path Colors
  • May 2, 2013
  • 6 replies
  • 2665 views
I would like to see my tool paths in red, as they were in WF5. Creo plays them in blue. I would think it'd be in the options settings, but all I can find there is mill volume colors.
Any suggestions are appreciated.
Thanks!
i bet this is what you want
razmosis13-AquamarineAuthor
OK, I've played with this a bit. It doesn't seem to be very intuitive. You can go in and change the default color, or change the color of a set of feed rates, but then when you enter it there is no check mark - just an option to quit. That seems inconsistent with just about every other aspect of the software. All I really want is for all paths to play in red and not just in one particular mfg file, can't seem to get that to happen.
Have you used this with success? Maybe I'm missing something very simple here?
Matt,
I played with the feed colors a while back I don't think you can save them after you set them the way you want. I would be nice if you could but I didn't see a way to get them to stick.
