CREO4.0能不能每次打开都是全屏。
  • July 1, 2016
  • 5 replies
  • 7033 views
不用每次都按F11.
18-Opal
July 6, 2016
Are you asking if it is possible to open Creo 4.0 in full screen mode, by default?
你问是否可以在全屏模式打开的Creo 4.0 ,默认情况下?
Amit
茂陈_011-VisitorAuthor
yes.是的
18-Opal
July 7, 2016
You can set the config option windows_scale to 1 or open_window_maximized to yes or reserved_menu_space to 1.  You can find further information via the following article:
CS31876 - 在 Pro/ENGINEER, Creo Elements/Pro 和 Creo Parametric 中,如何设置软件窗口打开时的默认大小
If you don't have an account, you can create one here.
Amit
