Cutout/Merge Operation in Creo Parametric 2.0
  • July 27, 2015
  • 2 replies
  • 3337 views
Hi all,
I trying to subtract two solids in assembly but the cutout option is not highlighting, I am attaching Picture for reference, any one please help me to sort out this issuecreo.PNG
2-Explorer
July 27, 2015
I believe that requires the advanced assembly option (or whatever it's called these days). Do you have that?
see https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS67068
"Merge" and "Cut Out" menu entries, under "Component Operations" in Creo Parametric are available, when:
  • config.pro option default_ext_ref_scope is set to all or subassembly
    • To allow external references to components
  • License feature Pro/Assembly or Advanced_Assembly_Set is available
  • Components, used for cut out or merge, contain solid geometry
Martin Hanak
