cutting of solid part with surface
  • August 2, 2013
  • 4 replies
  • 14365 views
I have a solid part and I wants to cut that part in certain pieces.
For the cutting I have a surface.
How to cut that solid with surface
thanks
Best answer by ptc-5116183
I know one method to cut is
Click on the solidify and select remove.
Is this the appropriate method to do.
ptc-51161831-VisitorAuthorAnswer
That's the only way, really. You can use an extrude feature and cut up to the surface, but that only uses the surface as the termination for the cut rather than cutting away the entire shape of the surface.
What If I want to do the same in assembly.
Means I want to cut the assemble with certain profile of surface
