Datum Target Annotation Feature - Issue
  • June 26, 2019
  • 3 replies
  • 1682 views
My problem:
When I create the Datum Tag using Datum Target Annotation Feature and remove it, the Datum Tag name previously used is still unable to change and to re-use.
If I pick a wrong plane or surface I cannot rename the Datum Tag.
Is there a way to fix this issue?
Thank you,
Arek
Mahesh_Sharma
22-Sapphire I
June 28, 2019
@ArekTRI
Is it specific to part or with any new part created?
ArekTRI1-VisitorAuthor
Hi @Mahesh_Sharma
the issue is related to every new created parts.
regards,
Arek
Mahesh_Sharma
22-Sapphire I
July 2, 2019
@ArekTRI
Can you create a new part and share without removing anything with some steps to recreate the scenario?
