decal or color texture is not viewed in Creo View
  • September 26, 2013
  • 10 replies
  • 6153 views
hello everyone,
When I open an creo parametric assembly in creo view, the decals and textures are not viewed in creo view.
Is there a solution or workaround this problem?
Thx, Koenraad Achten
Dale_Rosema
See if this link helps:
http://communities.ptc.com/message/221181#221181
Thanks, Dale
kachten1-VisitorAuthor
nope, it does not work. Any other suggestions? 🙂
thx for looking into this 🙂
gr, Koen
save the ASM in Creo Parametric directly as Creo View File (EDZ, PVZ) and open the file with
Creo View.
What's the result ?
Regards kied
