Default selection to all files while importing
  • May 18, 2019
  • 8 replies
  • 3781 views
Hello, I am tired of choosing all files every time. Is there any way to keep option "all files" as default one while importing.
Emeritus
May 20, 2019
Hello @Ananth_Narayan please confirm which product you are using so your post can be moved to the appropriate product board for more exposure.
I use Creo Parametric.
please provide more details about import action you execute.
When I start assembling file of other formats (say .stp). I click on assemble and on the bottom it shows part file (.prt)- creo files. I will now choose all files and then choose the stp file. What if the part file is removed from default list and keep all files options so that I no need to change the option every time.
I don't think there is an option to change the default type of file to be assembled to "All".
And if you find yourself doing something repeatedly, you should consider recording a mapkey...
Mapkeys can be assigned to a button on the ribbon or the quick-access toolbar.
