Design Turn around time 2
  • June 19, 2014
  • 0 replies
  • 664 views
Could you please share your experience?
Revision Scenarios
1Terminal Change (Qty 4)
2Length Change
3Connector Change (2 x 4Pins)
4Connection Change (6 Wires)
5Tape removal (Qty 2)
6Tape addition (Qty 2)
7Notes Change
8Wire Color Change (Qty 😎
9Wire Guage/Style Change (Qty 😎
10Splice Change (Qty 1)
11Diode/Fuse Add
12Grommet/Clip Change (Qty 1)
13Grommet/Clip Reorientation (Qty 1)
14Wire Branch deletion
15Wire Branch modification (one branch out location to other branch out location
16Connector cross section view change
17Ferrite coil length change (changing from x number of turns to y number of turns)
For above scenarios how much your organization takes to revise any design for above mentioned scenarios?
ProductStepsHighMediumLow
Creo SchemeticsWiring Diagram
Report table
XML
ProcableSimplified rep of Master Assy. w.r.t. wiring assembly
Harness Component Placement in Model
Creation of Skeleton model & shrink wrap (extracting surfaces of simplified rep)
Co-ordinate System creation
Assembling harness parts (Skeleton model)
Importing XML
Network path creation
Autorouting of wires
Family instance creation
Flattening of Harness
Drawing creation with BOM Table, Cut sheet, Spool table, Connector view
Check-in / Check out in Windchill
Promotion request process in Windchill
