OliverGräbner
Did you know about ifx_translation.txt file?
  • March 30, 2017
  • 0 replies
  • 1989 views
Did you know that you can use the ifx_translation.txt file to translate your label and help text in the IFX Fastener Definition dialog?
The file is located in <IFX loadpoint>\text\<LANG>\ifx_translation.txt
You can translate
  • catalog label and help text
  • fastener data files (*.dat) label and help text
For each catalog/*.dat name you can add a label and help text as described in the list below:
  • <NAME>.Label for the translation of the name.
  • <NAME>.HelpText for the help text that appears when you place the pointer on the name.
Example:
The example shows how to add a translated label and help text for the ISO4014-5_6.dat fastener data file for german.
ISO4014-5_6.Label
ISO 4014 - 5.6 Steel
ISO 4014 - 5.6 Stahl
ISO4014-5_6.HelpText
ISO 4014-5.6 (DIN931) Hexagon head screw with shank\nproduct grades A and B
Sechskantschraube mit Schaft\nProduktklassen A und B
Note:
  • If you have the same name for a screw and pin catalog, you have to add the prefix "screws." respectively "pins." to show a different label or help text.
  • You can use "\n" to add a line break in your help text.
  • If you use LABEL and/or HELPTEXT in your *.dat file, then the translation is disabled.
See also:
Did you know about LABEL and HELPTEXT in *.dat files?
Library Translation Files
